hi all, i just want a bit of advice, i have a icos he15 boiler that has started to make banging noised when started, the panel all lights up as it should be after a few minutes it starts to bang and the burner light starts to flash this will countiue to cycle like this if allowed, i have noitced the pump in airing cupboard is lighting up power but nothing else where before i know this whould light up three bars, so i was just wondering if anyone could tell me if this sounds like a failed pump thanks
hi thanks for the reply, i cant hear or feel anything from it, when you say its in auto mode is this something i can change as pressing the button on it does nothing, thanks
Yes press the button and that turns it into manual and the bars should light up one for each press
Maybe new pump needed. I have come across same thing happening with other brands of A rated pumps. Fancy, more complex full of electronics energy saving pumps seem to not last sadly
dont have a meter so cant test sorry, cant feel or hear anything from the pump just the banging noise from the boiler when it starts up, ok if im looking a new pump what would you guys recommend as a straight replacement for mine
Sounds like the pump has failed, if it's silent with no vibrations & the boiler is now overheating / banging then it all concurs...
Nice easy DIY bank holiday project for you... I would recommend the grundfos 15/60... Not the alpha 2 again..
hi thanks for your suggestions but i now staring to be a bit worried as i recieved a message this morning suggesting my pump may be fitted wrong ? ok the pump in picture is mine, the bottom pipe is to boiler the top pipe is to small tank in attic and you can just see in the picture the arrow on the pump is pointing down to boiler which is below is this correct? as we have only been here for around four mths could it have been fitted wrong and is now just staring to go wrong, thanks
well thats a bit of good news, hopefully i can get a pump then over the weekend and get some heat back on, thanks again guys for all your advice, will post a update once ive changed pumps
ok update on my problem, finally got round to changing the pump for a DAB Evosta 40/70-130 and great news it has cured the problem all heating and water back up and running, just want to say thank you to all who posted a reply to me it was a great help will be back if i have any more plumbing problems thanks again tom
