bm1289
Can anyone help?
Went to new boiler install the other day with reports from customer boiler has explosive ignition.
This occurs when boiler starts to ignite..then boom!
Checked gas/burner pressures,Flue and tried varioys flue restrictor rings!
Vokera stated it must be flue or minimum burner pressure but all seem ok.
Also gettin 0.00010 reading on FGA which l think is high on a brand new boiler.
Flue length is 1600mm,also notice gas connection is 15mm into boiler but 22mm piped to last 300mm under boiler.
The banging also calms down when boiler starts hot!
Any help appreciated
Cheers!
Cheers!
