L
laike
dear plumbing experts,
as the title suggests i presently have a shared water supply to my leasehold flat, shared with 1 other flat directly below by a straight vertical supply pipe from the ground to the 2 flats run within boxing on the inside corner of both flats, accessible by vents.
i have received a quote from thames water and they are able to install a new supply to the edge of the property to be connected to my flat.
here are the relevant sections of my lease:
questions:
1. can the council (freeholder) refuse my going forth with these works? i have written them but they are giving serious delays in authorising permission. do i even need permission when i clearly have the right as written in my lease?
2. what steps must i take with respect to the shared pipe / other flat? can i simply install my new pipe and disconnect from the old one / cap it off? do i need to give them notice for anything?
3. is it recommended to consult a solicitor for this? i've gotten this far, is it really necessary?
thanks for your assistance,
THE FIFTH SCHEDULE above referred to
Rights and easements granted to the Lessee
2. The right of free passage and running of air Water soil gas and electricity television and
telephone signals or impulses or other services through the ventilators sewers drains
pipes Wiles cables and conduits and other services and conducting media which are now
or may at any time hereafter be in or under or upon any part of the Estate for the service
of the demised premises together with all easements rights and privileges proper for
repairing maintaining and reinstating the same subject to the rights reserved by the Sixth
Schedule hereto
THE SIXTH SCHEDULE above referred to
The right to the Lessor its servants or agents and the owners or occupiers of the other
flats their servants or agents at all reasonable times with or Without Workmen and Others
as often as need or occasion shall require to have access to and enter the demised
premises and remain therein for such reasonable time as is necessary for the purpose of
executing repairs renewals alterations and improvements to any part of the Estate or to
any ventilators sewers drains pipes wires cables and conduits and other services and
conducting media serving any part of the Estate which cannot otherwise be executed and
of complying with their respective obligations either hereunder or under any covenants
relating to any other flat the person exercising such rights making good forthwith
damage caused by such entry such right not to be so exercised unless reasonable written
notice has previously been given to the Lessee except in case of emergency
questions:
