should i have a room thermostat with my combi boiler.
View the thread, titled "should i have a room thermostat with my combi boiler." which is posted in Boiler Advice Forum on UK Plumbers Forums.
baileys
My plumbers say i dont need one as i have thermostatic valves on my radiators but the GSE says i do. Im in a two bedroom maisonette. [FONT=arial, sans-serif][/FONT]
Having a room thermostat should make the system more efficient. But you won't need the thermostatic radiator valve in the room where the room thermostat is.
You have to have one fitted. Don`t forget you can go for a wired thermostat or a wireless programmable room stat, which are very good.
Plumber says no but Gas safe man says yes. Who is fitting it?
All the extras cost money and if the budget was tight something has to go.
It will still work without a room thermostat but you will have less control and use slightly more gas
You should have one but it is becoming a matter of course that some are only pricing the bare minimum on jobs to keep the cost down. Just tell him you want one added to the quote.
Your benchmark will be filled out (hopefully) and there is a requirement to provide interlock. A room stat is the simplest and most common way of doing this. I would be questioning whether you have chosen the right installer for the job if they do not recognise this requirement regardless of personal opinion. If we could pick and choose what reg's to abide by then it would make the job a lot easier but ..... Unregulated?
Well he has just been round to bleed the rads because most of them were cold this morning and he still insists that i dont need a room thermostat, i asked him if the boiler will be more efficient if i have one and he said no.
I never asked him to do it as cheap as possible, i just asked him for a quote for heating and presumed he would offer me what i needed. Everybody i know with a combi has a room thermostat but he says you only need one if you have a big house.
As far as I am aware it is regulation and my mate had a gas safe inspection last week on a system I forget the details but was not a complete new system he has had a letter from gas safe stating a thermostat has to be fitted ?
I will find out why ?
Ok thanks.
Of course it will be more efficient as you are not cycling the boiler and heating up pipework when no rads are calling for heat !
Have you had different people fitting the boiler and the radiators?
What does the quote say?
Reply to the thread, titled "should i have a room thermostat with my combi boiler." which is posted in Boiler Advice Forum on Plumbers Forums.
baileys,
baileys,
