M
MBPlumb
Hello everyone, I have been working on a few caravans recently and they a lot of them have these Sime format 80 B installed. I seem to be getting a common problem in what I can only describe as either a kettling noise or as if something has broken off and is trying to get through the heat exchanger. It seems to do it almost straight away (within 5-10 minutes of firing up) and continues no matter where you have the boiler thermostat. Has anyone come accross this before or have any idea what could be the cause. My next steps are going to be a drain down, powerflush and then finally remove the heat exchanger if neither of the following seem to work. Here is a link to the video if anyone thinks they may be able to help.
MOV00637.mp4 video by B-no21 - Photobucket
Ben
strange one, i had this a few years back on ariston microgenus 2 32 kw 4 boilers affected the wrong pumps had been fitted 5 mtrs instead of 6 mtrs
Im thinking of trying to contact Sime about this as it doesnt seem like it would be a batch of them as the ages of the boilers vary. All within 3 years though. The vibrations they cause does worry me a bit, the strange thing is that the boiler thermostat works fine as overheating seem the most obvious answer.
thats very strange one, probably granny and eggs may spring to mind but if drained and flushed the corect level of glycol needs to be added afterwards.
