A
AJH
I hope someone can help me
I have a wet UFH , 8 valve ambiente manifold . I have both stuck flow meters, faulty actuators and actuator valves stuck open.
What do I need to do to replace the flow meter or clean them and is it easy to remove them?
How do I remove and replace the faulty actuator?
The valve under the actuator is stuck open can I remove it and clean it ? how do I do this?
What do I need to close off to ensure I can remove the above without getting water everywhere but avoid having to drain the whole system?
your wisdom will be greatly appreciated
