J
Jeffrey Cumpsty
Can someone please suggest my next course of action...
I have an upstairs toilet that will not flush. When flushed the bowl fills to the top, the water can be heard trickling down the pipes, and the level slowly drops to normal.
A downstairs toilet flushes fine.
I have tried a snake down the blocked toilet and encountered no blockage.
The upstairs toilet is at the top of the wasste stack. The waste stack is inside the house and has an Air Admitance Valve fitted. Replacing this with an outside vent is not an option. I have tried unscrewing the cap off the valve and it made no difference. Could this have anything to do with it?
I also removed the pipes from the back of the toilet, and checked manually for blockage in the 4" waste pipe. There is none.
any ideas?
any ideas?
