Dreadnought
Hello.
Just moved into a new house - water/heating was not working so I got it serviced and now is up and running.
Once the guy had gone, I see I get a (small) dripping discharge of cold water from the discharge pipe.
Water is always cold.
When hot water is not being heated, it stops dripping.
I phoned the company who did the service and the guy who did it said "You need a new unvented cylinder, we can give you a quote".
The cylinder is an Oso (bubble) - he said it is probably losing pressure all the time.
But I simply could not get an explanation from him to demonstrate his logic or reasoning. All he wants is to replace the cylinder (£££).
Clearly there are a number of faults that will give rise to venting of cold-water and all I want is a reasoned argument as to why is *must* be the cylinder !
Advice please.
Get someone else in to look could be simple as a TPRV worn
Or an external expansion vessel may be needed
Wouldn't just jump in to saying need new cylinder
It's a bubble top cylinder so the bubble has most likely gone.
You need a G3 qualified plumber to come look to be sure tho as if it's not the bubble then it's a problem with one of the safety controls and can't be touched by anyone without a proper ticket.
