H
hwads
Hi
My parents have a vaillant TURBOmax Pro 24 E. installed about 2001 (ish)
The problem is when we want ch the boiler fires up then burner lights for about 10-15 seconds then goes out, after about 1-2 minutes it lights again then off again and this is repeated.
The flow pipe from the main heat exchanger to the diverter valve is hot but the pipe from the diverter valve to the rads is cooler and cold after about 1 meter or pipe.
Also when i remove the chrome screw from the front of the pump a fine jet of water sprays out constantly, the pump sound noisy and it gets very hot even though the return pipe is cold.
The hot water is fine, Just no heating
Any help greatly appreciated.
Thanks.
Can anyone tell me if the pump is normal when removing screw?
Thanks.
