biddy.63
Hi can anyone help with two seperate boiler faults 1) baxi 105e no dhw intermitent then 1st fault light flashing ) i reset and everything fine till i was gone. checked flame sensing probe and dhw flow switch, called back and changed diaphram. all ok till later fault light flashing no hot water.
2) ideal icos F.L fault showing, i reset and it fired up for 30 mins and locked out again. i cleaned condensate drain out and checked flame sense probe dimension and contiuity, this time it wouldnt fire up when it had for short periods before could it be ignition probe or gas valve solenoid. ANYONES HELP APPRECIATED
