philipb
Hi guys,
Went to a house last week with bad water hammer on hot and cold,fitted a prv on saturday
which stopped it,the factory setting on the prv was 3 bar.all seamed ok till today when it returned
but only on the hot.preasure still same but pipes banging on hot only.It has a combi boiler and i put the prv
on the cold main after the stop tap.any advise would be appreciated.
Hi I should have said that the house has not had this problem for years
then suddenly this and no plumbing work done,anything to do with the boiler?
clip all pipework (not nailclips as i once used them and after a year they had relised and the hammer came back rather than calling me they called another plumber who happend to be a mate of mine but they were slagging me off anyway ha ha we all live and learn) and put resistors on all washertaps
Toolstation > Plumbing > Valves > Mini-Rester i was told you could solve a problem like this by teeing off the main cold water pipe somewhere and in a way create a small (maby 6-10 inch) deadleg , air would supposedly trap here and act like a expansion vessel!!!???? . dont know if its true or if it works, but they did this in the old days if they had the problem when a ballvalve closed off ....... so i was told!! maby somebody here could confirm this!!! you could also add a small expansion vessel like this somwhere on the main Mini Expansion Vessels - altecnic | reflex
