L
Louise Flynn
Hi, trying again now i have registered!
This morning there was no hot water upstairs, but, there was downstairs. I had a look at the boiler and the water pressure was almost 0. After much tinkering and googling I have managed to reset the water pressure. I have an old Worcester Bosch boiler. So, now the hot water IS coming out upstairs, but, the light on the boiler to indicate that the hot water is on does not come on. It does come on when the taps downstairs are on. Is this a problem? Does it indicate that there is still an issue?
I have since put the heating on and now the pressure is going up high, to around 2.5 - is this the same issue/problem? I am not sure if I have done it correctly or if something else needs fixing.
Thanks in advance,
Helpless Female!!
Exactly. Your problem is internal to the boiler. You need a gas safe engineer to look at it.
Whereabouts are you? There may be one of us nearby can help.
I'm in Salford. I turned the heating off and the pressure normalised. Now there is no hot water upstairs. That's weird right? Only hot water downstairs, only hot water upstairs if the heating is on. Should I try bleeding the radiators?
