macka09
Hi all. Out of about 80 boilers I helped install with my previous colleague, not once did we check mains water pressure or flow rate. Do most of you guys actually check this when quoting a job or on installing a boiler to make sure the boiler will operate effectively? Or do you just open up the cold tap and judge it?
Thanks again.
Once you test a few you have an idea what your looking at and you can judge just by opening a tap, but if it's looking low always test them
A good test if the water hits the sink and splashes back into your you have enough 😀
Its something we should always be doing and not just presuming especially if it's in an area or region your not used to working in. Different in home town as you get to know pressures but still best to check in case of problems.
Always check mate, you'd look a right plonker if you didn't and the main just dribbled out, don't forget the boiler hex residence takes a bit off as well!
Only takes a min :44:
