perkstar
Dear Plumbers of the United Kingdom, I humbly throw myself at your feet and wish for your collective intelligence. Please go easy on me, I am not a plumber nor will profess to be, I am here to get advice in the hope of not getting seen off.
I have a gravity fed system in my 4 bed detached house. It was built in the 70's. One bathroom upstairs and we have a shower above the bath, the shower has it's own feed coming off the supply which feeds the bath, sink and toilet. (hope i'm making sense). The pipe work goes from the airing cupboard and underneath the floor boards to the bathroom.
The water pressure to the shower is awful. So I've had the plumber round to make a suggestion.
Option 1 - a 2 bar pump fitted into the airing cupboard, however this will activate whenever someone uses the taps, toilet and shower upstairs. My missus has a bladder the size of a wallnut and I don't really fancy being woken up by the pump at 2 am because she needs to tinkle. Cost for this work is circa £600
Option 2 - a unvented cylinder being installed, apparently this will increase the pressure upstairs to the same as it is downstairs which is currently 14 litres per minute (please correct me this sounds wrong). The advantage being that it will be quiet and should make the shower ok to use. The downside it will be around £1900 for the job.
At the end of the day something needs doing and we are lucky enough to have an electric shower downstairs which we use day-to-day. Having and electric shower put in upstairs is not really an option.
a) do the prices for the job seem about right? (appreciate every case is different) and b) are there any other options?
I've seen the shower power booster from the bloke on the dragons den. This seems a cheaper option but haven't seen any real world examples of the increase in pressure.
Hope that all makes sense. If you have any advice it would be greatly appreciated.
Cheers
Perkstar
Cheers
Perkstar
