G
gasmannn
What is the tee on gravity hot water flow near boiler? It's a spring loaded valve! Is it a non return or anti gravity valve?
no it just floods the lounge if the f+e blocks or vent blocks it has no bearing on circulationWhat does it do? Can it prevent circulation?
Fit a pump
.... a spring loaded valve ....
Their worst sin is probably weeping a bit , then furring up -- Will they still operate as a PRV ?
Most of them never would have in the first place as they were tightened down so much they would have held at 10 bar.
