R
raze1000
Hi all
Central heating is fine, hot water is only slightly warm.
I replaced the whole diverter valve last year because i was trying to find another fault (boiler clicking on and off and C/H not always kicking in) which proved only to be the c/h sensor.
I now only get lukewarm to cold water even though the boiler is firing up as normal.
I checked the diaphragm to see if it had got clogged or stuck so drained the system etc removed the 8 screw part of the diverter valve. It was all clean as a whistle and diaphragm not stuck or deteriorated.
Is it possible that the rear part of the diverter valve may be stuck as i only checked the diaphragm part this time as it is a fairly new complete valve.
Is there a part in the diverter valve apart from the diaphragm that could get stuck and cause C/H to work and water not getting fully hot?
When the tap is opened the the valve does push the plunger onto the micrswitches to fire up the boiler but as i said earlier no hot water.
Any help much appreciated.
Ray
are the contacts on the microswitches working and def making contact with the pin..try by manually pushing the microswitch does it fire the boiler up and give hot water
If the boiler is running at full tilt all the while the hot water tap is open then it must be losing the heat around the CH system which suggests a problem with the diverter. Try it with a cold heating system and test the CH flow pipe from the boiler when calling for hot water.
Just replaced diverter valve.
Now i get hot water.
When C/H is on the return pipe is cold and downstairs rads are only warm, boiler shuts off after a couple of minutes and kicks back in again after a couple of minutes and keeps cycling like this.
I removed all air from system. Shut off upstairs rads and got 2 rads hot downstairs and the other warm.
Still the return pipe is not hot.
When hot water is run, the water is hot but the C/H flow and Return pipes are red hot.
Pump is running ok.
Would this mean the new Diverter may be stuck?
Doing me head in now.
Ray
Have a look inside the pump. Cycling like that usually means poor circulation. It's even worse when you get a clever boiler like a Vaillant. As soon as the flow temperature is 30 degrees more than the return the thing shuts down to minimum flame and waits for 20 minutes. When I have a day or two to listen to their telephone answering system musack I might ask their tech dept if there is any secret way of changing the parameters!
cheers graham.
Decided to call it a day after faffing around.
Just got British gas in on a fixed price £127 inc parts and labour. Had to join the £2 a month member scheme but can cancel at anytime.
Guy came and reckoned the new Diverter Valve is duff so he's changing that tommorow. Would have cost be £90 for a new bosch dv anyway so hopefully all will be sorted for not too much extra.
Thanks for your help anyway
Ray
Just a note to raze1000. yer vaillants have a partial load setting at installer lever which is normally on auto. You can reset it to what you want in kw. depends what set up you have. Last one I did was an 831 on an underfloor and it had to be on max (24kw) to work properly. Different Vaillants set up slightly differently so check manual.
