N
Nicko131187
hi, im having trouble with a worcester 30si combi boiler, the pressure keeps dropping after 24 hours and having to re pressurise the system in order for it to work again, water is constantly dripping from the pressure relief valve pipe on the outside of the propertie where it exits, i have changed the valve as thought it might be the problem, the pressure when the boiler is on is about 1.5 bar, and doesnt go up when boiler is on so it cant be the expansion vessel. after changing the blow off this problem still occurs.
any help would be great as problem with customer needs solving
Many thanks
Many thanks
