L
loki2120
Just had my Worcester 30 HE boiler installed after it has been sitting in my spare room for 18 months ( uninstalled from previous house ). Everything is working perfectly apart from the cental heating will not switch on. Boiler is running at the rite temp, bar pressure is perfect, showing no error codes, no problem with hot water. There is no timer or thermostat fitted as the boiler is always run in comfort mode, so no need for them.
All the radiators are new and have been flushed and blead.
The cental heating switches on when i press the Chimney Sweep button, think this cleans the system out. The boiler heats up to about 94 degrees and everything works perfect, all the radiators or red hot. Once the cycle has finished central heating switches off and radiators go off.
Can anyone offer any advice on what could be the problem
