Hi all,
Firstly I'll point out I'm not an unvented installer 😀 bare with me
I was having a day dream the other day and was thinking about what would happen if you took a regular tank fed, open vented hot water cylinder setup, removed the cold water tank, plumbed the cylinder cold in conection directly into the mains and put a non return valve on it. Then disconnect the vent pipe, and instead, using a 22mm tee directly right after the hot water draw off pipe, right above the cylinder, put a pressure relife valve on one branch of the tee, and expansion cylinder on top, on the other branch of the tee.
Assuming the regular vented tank fed cylinders can take mains pressure... and not just fail (yes I know they were never meant for it) is there anything atchually fundamentally wrong with that? Hypothetically speaking if it wasnt going in someones house...
how about if you wacked a pressure reducing valve on the cylinder inlet to bring the pressure down alot, after the non return valve before the cylinder.
