Discuss Pop quiz, does anyone recognise this radiator valve? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi
Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Re Pack the gland under the shield
How do I remove the shield? Are you referring to top half of the chrome bulkhead? Thanks
Yes it unscrews
Undo the big slotted screw ontop of the head control wheel and remove the control wheel
Then use some rubber gloves or a rubber strap wrench or you can use an adjustable spanner on the top flats and the top part of the shield will unscrew you might need to use some grips / pump pliers note this will mark the brass but last resort
Then come back with a picture
Reply to Pop quiz, does anyone recognise this radiator valve? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
PSxxxxxx
