Discuss Can someone please identify what this hose is? in the UK Plumbers Forums area at PlumbersForums.net
Hi
I have a kitchen mixer tap which allows the top part to pull out as a hose (like american sinks).
It has frayed and I need t replace it, can you please identify what type of hose this is please and thanks
I've uploaded 3No. photos
It’s very unlikely someone here will be able to identify the hose itself, but they might be able to identify the tap if you provide good pictures. The hose is likely tap/manufacturer specific.
As Timmy said, a lot of those hoses are manufacturer specific.
*Well the hose would be of a standard size, but the end connection points are the issue.
I have never seen one with the connections as per your pics.
You will have to find brand of tap and contact a supplier.
Be prepared for a shock, you may end up paying almost as much for a replacement hose as you would a new tap.
Reply to Can someone please identify what this hose is? in the UK Plumbers Forums area at PlumbersForums.net
