Discuss Is it necessary to earth bond a Kitchen Sink? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal requirement for earth bonding but I would welcome views on this.
Best consultant a spark as it depends on what consumer unit you have
I believe that if the consumer unit supplying the kitchen is fitted with RCD protection for all the kitchen circuits, eg. appliances, power points and cooker etc. then supplementary bonding is not required.
If you can't be sure that there is earth leakage protection in the CU (RCD's or RCBO's), then best to add the bonding you are enquiring about, which I guess is what you may have decided already!
Please let us know how you got on. Would love to see a photo
Reply to Is it necessary to earth bond a Kitchen Sink? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
I need to replace an old leaking kitchen tap at a rental property and having fitted one of these before I've decided to go for the Cooke and Lewis...
3K
We are replacing our kitchen mixer tap, but I haven't figured out how to remove the old one yet as I'm a lowly DIY-er and unfamiliar with the...
2K
Hello! Advice required, please. Trying to understand implications of pipe size, length of run, and number of junctions etc. en route between the...
2K
Hi, I have a bit of a strange problem. A handful of times I've had a leak from the kitchen ceiling. This has always occurred when there has been...
Peterbromley
