- Messages
- 653
Please advise on which hose you use to drain down with?
Discuss Best drain down hose - what do you use? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ll second that. Had mine so long the jubilee clip last week.I use one of these Drain-Down Hose Kit didn't pay that much got it with points from boiler installs, nice and easy to roll up.
Have got the same and definitely good piece of a kit. Even though the price is quite high but worth spending when working a lot on central heating systems.I use one of these Drain-Down Hose Kit didn't pay that much got it with points from boiler installs, nice and easy to roll up.
Powerflush/magnacleanse hose
Same stuff but there's a place not far away that manufactures it. I bought 1/2" and 3/8" hoses for draining and siphoning off. I also bought some 1 1/4" for something else.
I have had them for Donkeys Years now. They have got shorter by 2" every so often as I sometimes cut bits off when the ends split. I use those hoses because I can see through them and they seldom kink.
There you go, an in depth report on the hoses used by Last Plumber on a day to day basis.
Purge ?
Just been gifted one of these via Installer Show but yet to use it.
Syphon Sucker – Sucky Little Mucker
There is another version of it around but cannot remember what it is called.Let us know any updates/ cons please as I'm interested but the price is a sticky point
Reply to Best drain down hose - what do you use? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
