Discuss Sewer pipe problems not sure about it in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all
Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my toilet a good few times nothing is going to the sewer so don't know is there a blockage or what way it works many thanks and advice would be grateful
In many parts of the country there are two systems. One is for rainwater, with open gulleys below downpipes from gutters, etc. The other is for disposing of 'grey/brown' household water (from washing, baths, showers, toilets, etc.) The two systems are separate.
Thanks so much it's just the drain where water comes out from kitchen sinks that is stinking really bad just don't know what to do as I have decking above the pipe work etc thanks pal
If the gulley was blocked for more than a short time the grey water from the kitchen will have spilled over and soaked into the soil. The smell will likely persist while the organic matter, especially fat, in the grey-water breaks down in the soil. Unfortunately, boxing it in with decking will probably prolong the time needed for the smell to dissipate by preventing sunlight and rain getting to the affected area.
IMO, you need to install an inspection hatch in the decking so you have decent access to the drain for cleaning and maintenance. (This should have included when the decking was installed.) If the smell persists for longer than you want to tolerate it for, get a drains specialist to advise. It's not my area of expertise but AFAIK the usual remedy is to treat the contaminated soil with hydrated lime. This is not something an amateur should attempt as the stuff is dangerous and there's an obvious risk of pollution.
Reply to Sewer pipe problems not sure about it in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
We have a problem with a downstairs bathroom toilet. When flushed, the water in the bowl rises, as does the water coming up from the shower drain...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
About 10 months I started having issues with a gas like smell in my home and the gas board was unable to find any gas leak I've still got the...
Hi, So i have lived in my house for 20+ years, (1990 build) its a detached property, corner plot with various manholes in the garden. In the...
