Discuss 1 1/2 adapter for 4 soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ih1
Need to take a kitchen waste under floor. It's a 4 inch plastic stack there no room to cut it with a saw so need to use a hole saw. What's the best fitting to use no a fan big fan of strap on boss's
hi woody its hurdy .:walkman:when using solvent weld,make sure plenty is used blather pipe and blather boss . just make sure both areas are clean . there should be no trouble.
If a strap on boss is fitted properly, with the hole cut the right size and the surfaces clean then you will never have a problem
I like to use the strap on with the gutter bolt in for a better hold!!
( wait for the double entendre's to roll out)
Use a solvent cleaner and a 57mm hole saw and it will work a treat.
Reply to 1 1/2 adapter for 4 soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
