W
Welder
Maybe we should leave the use of tools & installation etc cos although I would expect some basic technique's to be taught most would be learnt & perfected thought out the site training & is mainly down to the trades people they will be working with.
Should they still be taught screwed iron ?
How about just the college theory side, what do you think should be taught as part of the course?
Is this the knowledge you would want from your training?
What have I missed?
- Cold & hot water systems - should this include the Water Reg's & Part G (unvented so that they have the tickets on completion) Should it include sizing pipes & storage vessels.
- Above ground drainage systems - should this include below ground as well ? at least they should be able to ID separate systems, combined & surface water. How about grease traps, should guttering & RW systems be included ?
- Heating systems - should they still learn about gravity systems, how about heatloss calculations manually ? Low Lost Headers & hydraulic separation? Controls - should we be teaching WC / load compensation or just limiting it to the S & Y plan & combi plus ?
- Electrical - clearly it is such an everyday part of our work but to what extent? should they understand house wiring systems or just how to connect to a FCU ? Should they be able to understand & wire up an S plan & then fault find on it or is this just too much for them at this stage?
- Business studies - should they know how companies are set up & run / managed? Taxed? The high end skills that Dave is after would be wonderful but not sure they could be taught at such a young age although the personal skills could be pushed more, the rest I think come with age & experience.
My son is a Plumber but doesn't want to clear a blocked bog, instead passes it over to the drainage side What is the world coming to?
Dont blame your lad one iota Ive had septicaemia through dealing with sh1te. Not fun i can assure you
