Discuss 17mm solder sleeve online? in the USA area at PlumbersForums.net
Does anyone know where I can get a 17mm solder sleeve online?
I have a copper pipe outside that has burst and the diameter measured by calipers is 17mm.
Everywhere I look for a sleeve only has 15mm or 22mm, no 17mm sleeves.
Thanks.
Reply to 17mm solder sleeve online? in the USA area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
