Discuss 18mm cement board for bathroom flooring? in the DIY Plumbing Forum area at PlumbersForums.net
gmartine
Third time I'll be doing this floor...first time was weatherproof TnG, 2nd was marine ply both of which were varnished and blew up because of a combination of flooding and careless use. Hardibacker is easy to get from sheds but only in 12 & 6mm which I could overlay. Any other recommendations?
Marmox board ?
If customers are as daft as they sound- treat it like a wet room.
18mm wbp then 10mm wedi/marmox/etc and tape all the joints.
Or 18mm ply and then membrane it with Impey waterguard.
I'll look into it, can it be installed directly onto joists?
Donā€™t have a clue but you can make a seat out of it so has to be self supporting and able to span you may have to installing noggins every 450mm
Reply to 18mm cement board for bathroom flooring? in the DIY Plumbing Forum area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
