Discuss 1970s bathtap washer problem in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
K
kriswales
i am trying to change the washer in a 1970 bath tap that's dripping i cannot find any screw that holds the tap spindle on there is no screw in the side and nothing apparent under the blue plastic indicator any ideas please
Could it simply be shoved on? Even the old ones with the screw on the side are typically so tight you need to use the tap thread and a spanner (ideally a couple of blocks of hardwood but no one will pay you for the time to rig all that up) around the spindle to jack the head off.
Reply to 1970s bathtap washer problem in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
