Discuss 19mm overflow repair ? in the USA area at PlumbersForums.net
I have a 19mm ABS pipe passing through wall to exit over an outside drain .... routed 'internally in the inner timber frame wall' to provides the condensate drain for boiler.
The piece that stuck out of the wall has broken off leaving pipe flush with brickwork.
If the pipe was outside brickwork I would repair with a standard 19mm solvent weld coupler ... but as the pipe is in the brick, I need an 'internal coupler' to do the repair ..... is there such a thing?
No I don’t believe there is you might be able to find an abs pipe to fit the inter dial tho
Take a brick out and use a sraight coupler. Or chisel around the pipe to make a clearence first, only needs to be 5mm bigger than the pipe and maybe 15mm in depth.
The condensate pipe must be plastic – usually solvent-weld fittings – and at least 22 mm in diameter. Copper or steel pipework cannot be used.
[automerge]1588890254[/automerge]
You shouldn’t really be using overflow pipe on a condensate drain anyway
What pipe are you using?
Obviously plastic but 32 min now , I dont know any manufacturer that says overflow pipe is ok .
Maybe he has 22mm inside and 32mm outside? I would personally not run outside. Unless there is no choice then as you say 32mm.
Reply to 19mm overflow repair ? in the USA area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
