Discuss 22mm bath taps with 15mm pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I've just picked up some bath taps for my corner bath, and notice the pipe fittings ar for 22mm, however my pipework is 15mm (all my pipework is 15mm as I'm on a combi boiler).
Can i just convert the 15mm pipe into 22mm pipe just before it gets to the taps, or should i make the entire pipework for the bath feed 22mm?
The taps are brass bath taps with a mixer switch for the shower hose
Reply to 22mm bath taps with 15mm pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Most grateful for any advice on the fittings reqired to enable 22mm feeds into the mixer taps via the chrome extension pipes customer supplied in...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
A
The bath taps have 22mm inlets currently the cold water mains 15mm is fixed to the tap by a copper adapter 15mm to 22mm. The hot water is 22mm...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper...
