Discuss 22mm to 28mm boiler in the USA area at PlumbersForums.net
hi all Iam installing a new combi oil boiler the old boiler (system boiler) had 28mm feed and flow connections new combi has 22mm Iam ok to connect the 22mm straight into the 28mm pipes
Yep doesn’t it come with female threads eg for a male iron ?
For the same flow rate through 28mm the velocity will be less but that doesn't really cause problems on small domestic systems.
The system will still work fine.
Yea only issue if your 50kw plus heating load
Reply to 22mm to 28mm boiler in the USA area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
