Discuss 3/4" connection for concentric mixer shower? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Does anyone know of a concentric mixer shower valve that will fit 3/4" threaded connectors coming out of the wall @ 150mm centres?
I would like to replace a bar mixer valve (3/4" threaded connectors @ 150mm spacing) with a concentric mixer valve, but concentric mixer valves all seem to fit onto 15mm pipework coming out of the wall. I would need to break into the tiling and the wall to change the threaded connectors to plain 15mm pipe, which I would rather not do. There are plenty of bar mixer valves that will fit straight onto 3/4" threaded connectors but I haven't found any concentric mixer valves that do. Just wondering if anyone else has come across this?
Any chance of a picture of what you mean ?
Reply to 3/4" connection for concentric mixer shower? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi, I'm looking for a water pump to pump water from a storage tank at a constant 3 bar pressure. It's at a campsite I run that's at the bottom of a long, steep hill. We struggle with very high and often fluctuating (around 7 bar) water pressure, which wreaks havoc with our water heaters. I've...
