Discuss 3/8 inch/10 mm square stopcock key wanted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
robinmj
I can't locate a key to turn off the external stopcock. I can find 3/4, 5/8 1/2 inch square keys, but not a 3/8 inch. I've tried a tapered socket without success. Help gratefully received!
Thanks Redsaw, but it's about 2 feet down inside a smallish (c 6 inch diameter) plastic lined hole.
Removed
Edit; Only meant to show the socket
expect so as normal, done loads. should just be able to reach down to it.
otherwise get 3/8'' socket set ext bars and use the square hole bit over it and other end in a chuck to turn.
thats how i wind my car jack as thats 3/8ths
Reply to 3/8 inch/10 mm square stopcock key wanted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
