Discuss 3 port valve problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nick Cox
Why does my heating only work when hot water is satisfied, the motorised valve only opens when hot water is up to temp when I turn up cylinder stat valve shuts again. Worked ok for long enough wondering if its the synchron motor but it seems to open valve ok when hot water is satisfied.
If it's a Honeywell System W or similar, with either/or diverter valve (not mid-position) that's how it's meant to work. How long is long enough? Maybe you didn't notice it all summer as CH wasn't being called.
15 years plus its a mid position valve
OK, sounds like it could be an electrical problem with the valve. In case you don't have it, wiring diagrams below, showing both the overall system wiring and the valve internals. Might be worth trying clean the switch contacts. If it's not that, and it's getting the right voltages when it should, sounds like a replacement head needed.
It seems to be working as a W-plan. You could just leave it like that. I have a W-plan and I don't find the time waiting occasionally for CH due to HW preference is a problem. Maybe different if you use a lot of hot water.
Reply to 3 port valve problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the...
I have a CH circuit on a 2 way zone valve. It’s a long circuit with 15 rads on it but rather than shutting down the last 5 rads in the circuit...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
Deleted member 120897
