Discuss 300 gallon buffer tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
holedoctor
hi i was offered a 300 gallon buffer tank made from steel(not stainless steel) i was told that a a lagging jacket went on fire and there is burn marks on the outside but they say it is fine. it has a solar coil in it should i have it pressure tested or would it be ok and are these any good or is stainless steel better.
thanks
You could use it as a buffer in a heating system but not for hot water.
Pressure test is probably advisable
thanks for the reply i was going to use it for heating what kind of insulation could i get for this is it possible to get the insulation you see on preinsulateted copper cylinders. in your opinion this would be fine as a heating buffer tank?
thanks
Yes fine, do you know the make as you will be able to get a lagging jacket from them.
no dont know the make is there some form of spray on insulation that would be better than a lagging jacket
Reply to 300 gallon buffer tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We have solar panels for our hot water, so we have the main water tank in the airing cupboard, plus a small pressurised (I think) tank. The...
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
1K
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi. I have a hot water high pressure problem that my heating engineer (and other engineers that he has spoken to) cannot fix. I’m hoping someone...
1K
