Discuss 6 in the Gas Engineers Forum area at PlumbersForums.net
What size are your existing and proposed boilers kwtThank you for your reply. Both 9kw or about 32000btu l believe. Will the meter be able to supply that much....
Hi Shaun. Thank you for the reply. Both 9kw. Will the meter be able to supply that volume of gas....What size are your existing and proposed boilers kw
Depends on size of meterHi Shaun. Thank you for the reply. Both 9kw. Will the meter be able to supply that volume of gas....
It's a 6m3/h meter Shaun will that cope with 18kw.... Is there any reason l can't use 35mm plastic yellow gas pipe after the meter under the ground. Thank you. MattSo heat only boiler in theory yes you should be fine providing the gas safe engineer works out there pipesizing etc
6m3/h. Will that supply 36kw?Depends on size of meter
Reply to 6 in the Gas Engineers Forum area at PlumbersForums.net
