Discuss 6mm radiator pipes to 15mm plinth heater??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
katie279
Hi all,
Am renovating kitchen at the moment and looking to replace an old radiator with an underplinth radiator to save on space.
The current radiator pipes are 6mm (yes double measured with calipers twice as surprised me!).
Any ideas how I can get this to connect to 15mm underplinth heater? Can't even find 6mm reducers, let alone one that goes from 6mm all the way to 15mm!
Am concerned it may require some pretty industrial refitting of the heating!
Is a 1970s build with oil heating.
Hmm just spotted BES have some - could have a 6mm to 8mm and then 8mm to 15mm thereafter??
Would this even work??
I think 6mm O/D is refrigeration pipe and it so there is no fitting sold that gets you from
refrigeration pipe to plumbing pipe.
Check in the BES catalogue online in case they have made one recently -
Basically refrig pipe is American o/d size and plumbing world is metric. However
there is a way of doing it as API 2006 (Solar) my outfit had to do this last year.
So if your serious I will go down to my small workshop and check what we did last
September
centralheatking
Good idea - I tried that - but no - look at page 158 part no 6786 which is a 15mm/8mm E/F plumbing reducer. Then you need to use old style plumbing on the 8mm e/f and solder it slowly and wipe it until it is strong. I think we swaged out out the end of the 6mm pipe a bit -
Def works anyway - there are 100's of these joints in operation now I know
Centralheatking
push the 6mm into 8mm and solder and then go from 8mm as required
Question is though whether or not 6mm will give you the heat output.....
Very unusual to find 6mm pipe on heating anymore. It was a thing from the early 60's / 70's usually on solid fuel systems.
The max heat will be around a kw depending on the run.
I'd strip it back to the main runs.
If you are determined to use it stick it inside a bit 8mm and solder it on.
Hello Katie and :welcome2:to the forum.
where does the 6mm pipe lead back to?
can you not replace it with something bigger?
Reply to 6mm radiator pipes to 15mm plinth heater??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
