Discuss cylinder thermostat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wightcorp
Hi all... thank you for your time.
I have a hot water cylinder with a cylinder thermostat mounted about half way up. It is set for 65 degrees C. When it reaches temperature it turns the boiler off (potterton suprima 60L) but it then comes straight back on again and repeats. I can here hot water been introduced to the cylinder coils to warm it up.
The temprature on the boiler itself is set to MAX (is this correct?)
I have changed the cylinder thermostat but the problem is still occurring.
I have test the thermostat in terms of when i manually turn it to zero it turns the boiler off (doesn't ask for heat) and the boiler remains off. When i turn it to 60 degrees the boiler turns on (asks for heat)
I am unsure if this is normal or not?
Once the cylinder reaches temperature, how long should it take to reduce enough for the boiler to have to kick in?
thank you
The differential will normally be around 10~c. The ideal position is about 1/3 from the bottom of the cylinder. How well insulated is the cylinder?
thank you for your quick reply, i think it is well insulated. What do you mean by the differential will normally be around 10~c. is this between the temp of the boiler and the cylinder stat or the amount of degrees before the boiler should kick in?
i seems to be constantly asking for heat even thought the cylinder feels very hot
thank you
When you replaced the cylinder stat how meny wires did it have ?? should be 3 possible they are on wrong connections.
Yes three wires and and earth black brown blue i have tried swich both normaly closed and normaly opens over but no joy
You may be getting a feed from J/Box or motorised valve
Hi yes its fed by a junction box and there is a motorised valve next to the cylinder nt sure how it works though my plumbing skills are very limited 20161004_154022.jpg20161004_154022.jpg
Reply to cylinder thermostat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
A
My boiler will not heat up past 50 degrees. This is the temperature that is registering on the esi thermostat. Radiators have been bled not sure...
Does anyone know of a weather compensation unit that can be fitted to a cylinder? I have an Ideal Logic Max H24 which heats a thermal store. The...
I need to change my shower mixer and I have a unvented hot water cylinder. Is it sufficient to turn off the mains? Do I need to drain the...
