W
wightcorp
Hi all... thank you for your time.
I have a hot water cylinder with a cylinder thermostat mounted about half way up. It is set for 65 degrees C. When it reaches temperature it turns the boiler off (potterton suprima 60L) but it then comes straight back on again and repeats. I can here hot water been introduced to the cylinder coils to warm it up.
The temprature on the boiler itself is set to MAX (is this correct?)
I have changed the cylinder thermostat but the problem is still occurring.
I have test the thermostat in terms of when i manually turn it to zero it turns the boiler off (doesn't ask for heat) and the boiler remains off. When i turn it to 60 degrees the boiler turns on (asks for heat)
I am unsure if this is normal or not?
Once the cylinder reaches temperature, how long should it take to reduce enough for the boiler to have to kick in?
thank you
thank you
