Discuss A series of UFH questions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, having seen how many people have had solid replies on here I thought I'd test the waters.
I have a 1920s semi detached, solid brick wall and suspended wooden floor with 2x lowered areas (kitchen and downstairs loo) that appear to be concrete (freezing floor in winter). I'm extending the house 4.3m back, the full width of the property and am very keen to install UFH on the ground floor only.
Any response to these questions would be greatly appreciated:
1) Trying to decide where I should rip up all the flooring and install 100mm insulation then UFH or use an overboard system. Have heard through forums some people have had good experiences with the Wanda EPS400 overboard system, but will that insulate sufficiently at only 20mm thick? They say the aluminium reflects the heat back up - has anyone installed this and found it does what it says on the tin?
2) Any other overboard systems out there that UFH installers have found has worked well for others in older style houses?
3) As I have an older house with no wall/floor insulation, should I get heating calcs done to confirm if UFH will perform adequately?
4) Anyone have a rough idea of the install cost for ripping up floorboards and installing a 'between joist system' and relaying a chipboard etc... on top - circa 50sqm for old ground floor. I feel it's better, but can't get a handle on the install cost difference between that and an overboard system.
Any help would be greatly appreciated.
I would recommend ripping the floors up to put insulation down first
Yes also might be worth going down the route of insulating them as well
I think point 3 is important. Nuheat makes systems with better heat outputs than the competition, but at a price. In my own centre-terrace with solid brick walls, I opted for floorboards boards up + insulation between joists and a fairly standard specification system and it works very well. But I did retain a radiator as a backup for when a neighbour goes on a winter holiday and turns her heating off.
The insulation and draughtproofing work means that the house is now much warmer and I don't have condensation forming in my carpet underlay and making the place smell of mould.
I probably wouldn't bother with an underfloor heating again, as I like to be able to sit near a warm stove/radiator, but the insulation is a definite winner. That said, the underfloor heating does a very good job of keeping the room at a good average temperature instead of having all the heat run up the stairs, and is good for drying washing.
As for 20mm thick insulation systems - well, it'll do better than nothing, but Recticel/Celotex/Kingspan seem to have a k value of around 0.02W/mK and I don't think any material will beat this, and 50mm of this is considered borderline for UFH, so 20mm sounds too thin.
Reply to A series of UFH questions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
B
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am looking to join a plumbing and heating engineer 4 days a week whilst I attend College to gain my level 3 plumbing and heating qualifications. if...
Billy Barnard
B
