Discuss Accumulator expense woes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello to all. I have a very insistent customer who was keen to have an accumulator/pump installed and at the final hurdle done a complete u turn and opted to put a cwsc (ground level!!!) with a Stuart turner negative head single impeller pump to feed a megaflo and cold to the bathrooms.
I advised against this!
Guess what? It only doesn’t work!
Is anyone aware of a pump that would perform any better or do we all agree that an accumulator set up is the only way forward?
I would appreciate all professional opinions.
Let the debate begin...
If your first attempt didn't work, I think you should contact Heatrae-Sadia and ask for their recommendations, e.g.:
Technical advice
Personally, other things being equal, I prefer accumulators over pumps just because they're simple and have less to go wrong; both qualities I like more and more the older I get.
Why what happens in theory it should work
Now if it’s a demand problem fair enough
Thanks for the advice. I’m a one man band and yes the *** packet has definitely been utilised on this one!
The customer in question used to have a building firm and is full of it from time to time.
Greatwater was the original suggestion
as an accumulator/pump to be installed
but the customer seems to think that set up a bit too expensive.
They are back on mains for now but asking could a bigger pump do more?
I always cover myself with my professional guarantee...
Dissapointment
Dab easysys
Thanks Craig. They’ll probably opt for that being “sneezed” in next!
No probs, I haven't installed one myself but I had quoted to fit one as a replacement for an earlier model, after speaking with grundfos these pumps are about as good as it gets. I would however speak to grundfos about the proposed system. Pressuring a megaflow might be too much strain on the pump motor.
I have
What’s wrong with the existing pump ?
Reply to Accumulator expense woes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
