Discuss Accumulator or not? in the USA area at PlumbersForums.net
HI all
ive got a unvented system in the loft at home. We had the water feed replaced and at the stopcock, we get about 2 bar, and 24l/min
Showers get about 10L/min and taps around 12l/min - both around 1.5bar. The house seems to have 22mm from the stopcock to the boiler and around the house, with 15mm feeds to the taps/showers. The showers are not a great experience currently!!
My issue is, if we go accumulator, i dont think we can find anywhere to house it near the main tap - can it go elseswhere on the system? or maybe in the shed?
And is there any other option other than accumulator?
Thanks for any advice in advance!!
Steve
I would not put an accumulator outside in a shed - unless it was trace heated
You could consider a pumped accumulator with a coffin tank in the loft dropping via a 28mm feed to a pump at ground floor level. - that would give you 40lpm at 4 bar for 20 to 30 minutes. I sell a lot of those systems in West London
Reply to Accumulator or not? in the USA area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi all, looking to solve my clients water flow issues. 5bed detached House in the South East with a combi boiler. Customer is unhappy with...
2K
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
