Discuss Acqua Tempus, shower timer with shut off for teens in the Plumbing Tools area at PlumbersForums.net
Hi to all member
I want to post this product I bought some weeks ago in a website in GB, it is called Acqua Tempus
apparently it is very simple but it is not: it is a shower timer with shut off; it is programmable and has a lithium battery that gets charged with the passage of water, son I do not need to replace any battery; the solenoid valve is inside Acqua Tempus, so no plumbing is needed at all. At a first sight, this product has been developed wisely.
I have 2 daughters, 14 and 16, and they took never ending showers (no less than 20 or even 30 minutes each, an absolute nightmare) my wife and I had to do something to cut off such expense on water and gas and this device is just what we needed.
The installation is very easy and seems to be well built: it is tough and easy to programm.
there is this video in Youtube: shower timer
I just wanted to share it here in this forum, I am quite sure some members will find it very useful at home as it has been for us
I hope it helps
regards
As it is installed within the shower can people not just press a button and continue showering?
Hi, the answer is no; when the shower time is gone, AT goes into DELAY TIME that can be set by us, just like the shower time, so when the user runs out of shower time, the solenoid valve shuts it off and leaves it blocked during the delay time; we have set a delay time of 4 or 5 min as far as I can remember;
it is not viable for my daughters to stay in the bathtub without water for 4 minutes waiting for another shower; so they've had to learn how to take a shower in a maximum of 8 minutes, and off they go. Otherwise, they would run out of water being soaped, ...., not recommendable in my opinion.
hope it is clearer now
Haha, 8 minutes may be an average time set by the disease control prevention center but I wonder what that does to the mental health of an average 16yr old girl.
some of you have sent me an email requesting about where to buy this shower timer; I live in the UK, here it is Leisure Controls Ltd who sells it. in the US or AU I have no idea at all, it is Spanish made so for those that wrote to me from abroad, you will have to find a local dealer in yor country or just write to Arelia and they will definitely let you know
just this so far
But does it simply shut the shower off totally?
Where I am currently I have a thermal store boiler (probably contains 30 litres hot water: enough for a 6 minute shower). You can actually have a decent shower with the boiler SWITCHED OFF as my Grohtherm mixer will maintain a set temperature to within 2 degrees of the hot water inlet temperature and the temperature then gradually tapers off to cold once the store is cooler than the desired temperature. Being a gradual drop, it allows you to finish rinsing your hair, but it is unlikely you'd want to spend 20 minutes under a cold shower. I can see a sudden stop in water flow altogether being quite impractical however, and, being extremely short sighted, I probably wouldn't be reading the digital display under a shower.
And what the heck is soaping time?
Hi there, with a 30 litre hot water tank you certainly do not need to install a shower timer with shut off but at home, we have a combi and my daughters know it; I considered installing what you have in my daughters' tub but it would have been too complex, expensive; Acqua Tempus is being a much better solution, and cheaper.
About the display , it is very easy to read and flashes when there is 30 seconds left warning it is coming to and end, so there is no problem running out of time when still being covered with soap or shampoo, and if there is, they will be more careful next time. We call this at home education.
soaping time is a parameter we did not understand and first;
it is the maximum time we have for soaping;
when the tap is running, you can see in the display time is counting down; but if you shut the tap for soaping, Acqua tempus turns into soaping time and does not take any shower time off, so when you reopen the tap, it goes back to shower time and the countdown starts when you left it.
and why did they introduce this parameter? the explanation they gave me was as follows: if I walk into the shower and have a really fast shower lets say 3 minutes, and I shut off the tap and walk off, there would be still 3 minutes left, so next person having a shower would oncly have 3 minutes left for the shower; but, as I walk out of the shower, it goes into soaping time and if it reaches cero, AT will presume that I have left the shower and it will reset all parameters and goes back to shower mode for the next user, this thinggy is very intelligent.
I hope I have been clear enough for your query
The product is indeed extremely intelligent.
Would it be able to determine if the user was doing something other than soaping during soaping time? I have 2 teenage sons in the house.
WOW!! that question can be a bit mean? naughty perhaps? what do u mean when you say "something other than soaping"?? having sex in the shower perhaps?
sorry about my assumption mate! ☺️☺️☺️☺️😉😉
Yes. And the device sounds very well thought out. As the main effect of the device is to save energy, it seems to make sense to encourage people to turn the tap on and off as required rather than leave it running.
The fact that there is a maximum inter-shower time is not something I would immediately have thought of myself, but as you explain it it makes perfect sense - otherwise the device would incentivise users to use the maximum allowed shower time in order to reset the module, which would encourage a bad habit.
yup!! that's it, just as you say
that's why we are 100% satisfied with this shower timer despite its price (it is not cheap at all)
Hi everyone
I have spotted this other shower timer with shut off Showerboss, apparently american made.
It is at first sight cheaper than Acqua Tempus, but going through it, it is not: it needs 12v power supply and the solenoid is not inside the timer, so it needs plumbing and an electrician and makes it far more expensive than AT. The AT is "plug and play", In add, the led display looks worse with less functions than AT.
Just this so far to compare with other products.
Hi, I would like to know whether the device reduces the waterflow during the showering time. I've got quite a high flow and like to keep that, I just want to stop some family members having excessive long showers as I can't be bothered to watch the clock whenever anyone takes a shower.
Hi kitty
It does reduce the water flow, bear in your mind it has a turbine to produce power and therefore charge the battery, so the turbine stops the water flow a little bit. Once installed, after a few days, you won't notice the difference
It is worth it
Hope this helps
Hi, I have finally bought one AT timer.
To be honest I must admit it is really well designed, easy to install and very effective reducing water and gas expenses. I have 2 children, I was thinking of killing them but finally decided to buy one Acqua Tempus to stop them from wasting gas and water.
The negative aspect is the price, only one distributor here in the uk, Leisure Controls, and the price is really high.
Anyway, nice stuff despite its price.
Very pleased to hear that you did not murder your children.
What is the payback period?
I don't know yet, we have installed it one week ago. Set as 5 minute showering for each of them and off they go.
Gas and water bills are definitely going to be lower.
In one month, I will come back to this forum showing figures.
One thing, really good : my wife and I are much more relaxed at home but don't know how to cuantify it in pounds.
So
"The price is really high"
You paid that high price because you are sure the item will reduce your gas and water bills (admirable)
This choice must have been been based on a calculation, even a rudimentary estimate.
Please share.
(Of course 1 month, as you suggest above is not a reasonable timescale for the estimate due to price fluctuations and seasonal use)
Thanks 👍
It is difficult to calculate the pay back period.
Since 2021 when we bought it, water and gas bills have dropped. 30 pounds a month perhaps in each bill.
And another "profit" is no more anger at home in the morning. The bathroom is usually unoccupied.
Despite is high price, we are satisfied with it.
Exactly. It's not all money. Getting a carpenter to do a really weird install for my kitchen sink to make it fit where it shouldn't cost me £220 and won't have added £220 to the value of the property. It may even have devalued it since I replaced the mixer tap with separate hot and cold (because Brexit means Brexit). On the plus side, I can wash up without worrying about splashing, water getting behind the sink, and having a plastic sink that is nigh impossible to clean.
However, the reduced stress and tiredness do mean I can work a week longer before having to retire so I'll get my money back with interest!
BY the way, the only negative aspect about it is the price: about 350 sterlings
not cheap at all
hopefully, we will get it paid back in not more than 4 or 6 months
Hi Spitfire72
I am writting to you from Arelia, the manufacturer of this device you are exposing.
We have come across to this forum because our distributor in the UK has told us some customers were talking about it positively.
I would like to congratulate you for making this decision of installing a shower timer with shut off. I presume and hope , your water and gas bills have dropped.
As you say, our product is expensive, quite expensive but it is not so much about the price , but about the money it saves day after day reducing your childrn's showers. Besides, all the components it has are top quality so that's one of the reasons of its price. And last but not least, this device does not need plumbing or electricity jobs son that is very attractive, it is DIY.
I just wanted to highlight these features so that you can reconsider your opinion about its price.
Just this so far.
kind regards
@Arelia
I admire your honesty when you say:
"our product is expensive, quite expensive"
That's a brave statement. Well done.
I appreciate your words.
As I said before, we use high quality components, we could make it much cheaper with low quality stuff but that is not our market nor the quality we give to our customers.
Thanks anyway 😉
Expensive but not dear, I think is the point s/he is making. Anyway, when did 'cheap' become a positive word?
One more thing, Acqua Tempus has a solenoid latch valve inside: we could have chosen a cheap chinese valve but we decided to mount Muller valves which are supposed to be the best in the market but also very expensive, same with the water turbine: we chose a model with ceramic shaft against water hardness but has a high price,....., And more components that are high quality.
All this together explains its price.
Reply to Acqua Tempus, shower timer with shut off for teens in the Plumbing Tools area at PlumbersForums.net
  • Article
Good Morning to the forum we would like to introduce our Acqua Tempus shower timer with shut off, particularly recommendable for homes with...
2K
  • Article
Good morning We would like to introduce our domestic shower timer with shut off - Acqua Tempus- especially recommended for homes with teenagers...
3K
  • Article
The Acqua Tempus shower timer is an easy-to-install device that restricts the maximum shower time, thus saving large amounts of water and gas. It...
2K
  • Article
I am sure you will join me in welcoming our newest sponsor @Arelia to the TilersForums.com family. We are very happy to have you on board...
2K
Help. So I’m trying to fit a shower in a bathroom in an old tenement flat in Edinburgh. Unfortunately the thread on the air off valve has broken...
