Discuss Add Cleaners normal bottles to Tf1 Fernox Omega in the Central Heating Forum area at PlumbersForums.net
Hello,
I wonder how to put Fernox cleaners from normal bottle to Fernox Omega filter. I do not want to use by radiator and it does not work with towel dryer.
Sounds good to use a regular faucet hose with a small pump? Do you need to relieve the pressure a lot and drain some water between Filter and Pump? I will turn off water so that not all water from all parts of the system comes out.
There is another way if you do not want to use aerosol. I live in Sweden and the price is more expensive for fernox products. Much cheaper with Sentinell and Magnaclean and others.
Cheapest way is to turn off rad drain some of rad add the inhibitor into rad easy to make up a filler. Then turn rad back on leave it to run for a bit then bleed rad. With express you do not need to drop pressure
Or use a pump sprayer and adapter to the omega valve
Reply to Add Cleaners normal bottles to Tf1 Fernox Omega in the Central Heating Forum area at PlumbersForums.net
