Discuss Adding extra radiators to central heating systems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Joely
Hi Plumbing world!
Ok I have had a client request for small radiator to be added to her centralheating system.
Now this will bethe first time I have added a new radiator to a system. I have obviously changed radiators, switched from single panels to double convectors and fitted a few heated towel rads etc (like for like) with a little pipe modification. I have been informed that the flat has floor boards.
The question is what are the golden rules?
Where is the best place to tap in to the flow and return ?
What happens if you get the flow and return the wrong wayround ?
How to balance the new radiator ?
Anything that you have learnt in the past that makes lifeeasier ?
Again thanks for all the support this forum rocks !
where is the new one going to be fitted and where is the pipe run closest to it?
how many rads already are fed from current pipes, what size (rads/pipes)?
Reply to Adding extra radiators to central heating systems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
