Discuss Adjusting the anti scald protection for bath in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
For some reason I'm not getting hot water coming out of the bath tap it's just coming out warm, it's fitted with these anti scald valves underneath the bath, I have taken the side pannel of the bath thinking it would be easy to adjust to see if that's the problem, looking at it I have no idea which way to turn it to, the wall left or to the right towards the bath. the cap I took of doesn't do anything it gives me a clue of what the make is its a Saracen 2/3.
It will go colder one way and will go hotter the other so just turn it a bit and see
might be the tmv3 is bad / broken
1. Turning the adjustment spindle anti-clockwise should increase the temperature, while clockwise decreases it. Clock / anti-clock while looking up at the adjustment nut from underneath.
2. Most of these valves have check valves fitted to the hot and cold inlets. These can seize up, particularly in hard water areas and / or if not often used. You would need to remove the TMV to clean / descale these.
Will certainly give this a go if not I will call someone in thanks.
Reply to Adjusting the anti scald protection for bath in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Sonya K
