Discuss Advice for replacement pool oil boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
I've a client with a rusty 20yr+ old Certikin 180 (44kw) oil pool boiler that needs changing. Certikins replacement looks like it is the exact same boiler. It has a riello r40 burner and non condensing 85% efficient boiler... Oftec say it wouldn't be compliant and would have to contact Building control for permission. Id rather put in a more efficient condensing boiler.
Any one with any ideas of a suitable modern oil boiler for a pool and pitfalls to look out for. Are off the shelf boilers easy to adapt to add a pool heat exchanger.?..
When replacing an old Certikin 180 oil pool boiler, it's a good idea to consider a more efficient condensing boiler. Off-the-shelf boilers can often be adapted to add a pool heat exchanger, but it's important to ensure compatibility and proper installation. When selecting a modern oil boiler for a pool, look for models that are specifically designed for pool heating applications and meet relevant efficiency and compliance standards. Consulting with a heating professional or contacting Building Control for guidance can help ensure compliance and identify any potential pitfalls specific to your situation.
Reply to Advice for replacement pool oil boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
