Discuss Advice on suitable thermostat and switch in the USA area at PlumbersForums.net
Deleted member 112484
I've an old (50yrs) oil boiler that is manually switched on and off using a light switch outside the boiler room. The only thermostat is the one built into the boiler. This is usually set fairly high and never touched. The light switch is use to switch on and off the boiler as heat is needed.
Ideally (to minimise the need for wires) I would like a freestanding thermostat that i can put into a room. When that thermostat reads "low" it will trigger the boiler to turn on.
Maybe this will require replacing the light with a receiver from the thermostat that will turn on and off the boiler. SO ideally the thermostat and receiver would communicate wirelessly,....
And if all my wishes were to come through I would be able to access the thermstat and switch on my phone
Are such gadgets / tech. available? If so, any recommendations would be much appreciated.
I'm UK based
Reply to Advice on suitable thermostat and switch in the USA area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
