Discuss Advice on which Boiler to choose in the Plumbing Jobs | The Job-board area at PlumbersForums.net
01010chris
I have been quoted on the replacement of my old conventional boiler with a condensing boiler. I have been offered either a Potterton Promax 15 SL or an Ideal Logic Heat 15.
Which would people suggest I opt for and if possible the reason why.
Chris
Go for a ideal logic + heat 15 (the plus is the important bit) gives more warranty 7 years.
Ideal logic are a great boiler , be sure whoever is fitting it services it yearly to keep up the guarantee and most important that they power flush the system first !
Reply to Advice on which Boiler to choose in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
